Syntax for Execute commands
Old   May 8, 2006, 15:04
Default Syntax for Execute commands
Astozzia
Hey there,
Can anyone tell me where to find the text commands needed when "solve-> execute commads" is used?
I am trying to display and then record an mpeg video of the evolution of cell squish index (unsteady simulation).
/di/sw 1 /di/view/restore-view my_view /di/cont cell-squish-index /* but how to tell I want auto-range? and the rest of the syntax*/
Thanks a million for any advice!
Astozzia
Old   May 9, 2006, 02:54
Default Re: Syntax for Execute commands
Gernot
1.) I donīt know if theres a list of all textcommands somewhere but you can find the way for all execute commands in the text-user-interface. For example when you print di (for display) in the tui and press return then all possible following comands are listed.
2.) If you end your di/cont.... comand with no value then the picture should be autorange.
3.) The comand for hardcopy the picture is :
di hc"nameofpicture_%t.jpg" (example for jpgs - I donīt know if there is the possibility to creat a film directly.)
4.) Do you print all your commands in one execute command line? Maybe itīs easier to take one execute comand line per comand
Hope that helps
Old   May 9, 2006, 12:03
Astozzia
Hi Gernot,
Thx for your answer:
cool! this helps indeed. However, how can I guess the abbreviations to enter in the execute command window: For instance, di <=> display, sw<=> set-window, etc. How about other commands?
Thanks anyhow, Astozzia
Old   May 9, 2006, 12:07
Astozzia
also, it still inconvenient I cannot find a way to create a movie directly via the "execute command" feature...
Any suggestion? Thanks Astozzia
Old   March 7, 2013, 11:54
Default lgn_aero
N/A
lgn_aero is on a distinguished road
As per my knowledge you only have the option to save images and then stitch them for the video. Of course that is quite easy. Download the application from the following link it is free and proceed.
http://mirror2.cze.cz/imagestovideo/ImagesToVideo.zip
Hope this helps
lgn_aero is offline   Reply With Quote
what is syntax error : missing ')' before ';' aleisia Fluent UDF and Scheme Programming 8 March 10, 2015 15:42
syntax error on config.h ehooi Fluent UDF and Scheme Programming 3 November 9, 2011 10:05
Please explain this commands. sri31049 FLUENT 3 March 20, 2009 04:38
OpenFOAM14 for Mac OSX Darwin 104 gschaider OpenFOAM Installation 118 July 20, 2008 05:19
error while compiling the USER Sub routine CFD user CFX 3 November 25, 2002 15:16
