Turbulent flow in tube and laminar flow in annulus |
March 9, 2013, 07:38 |
shahab
Rep Power: 14 |
Hi.I want to model heat transfer in a double pipe that turbulent flow of water is in the inner tube and laminar flow is in the annulus.how can i do this with fluent?
March 9, 2013, 07:46 |
If you can keep Yplus below 1, then try transition model.
Fluent has option to model both option in same model. You just need to define two fluids I guess. Last edited by Far; March 9, 2013 at 08:14. |
March 9, 2013, 08:01 |
shahab
Rep Power: 14 |
thanks for your help but my problem is in selecting viscous model turbulent and laminar flow simultaneously in tube an annulus respectively.
March 9, 2013, 13:53 |
Can you elaborate your problem a little bit more, because i think you need to specify either two different inlet boundary conditions or the alternate option i can tell you seeing your geometry or computational domain.
March 10, 2013, 05:41 |
shahab
Rep Power: 14 |
here's the more details about problem.There is a double pipe that hot water by turbulent flow goes through the inner tube and cold water by the laminar flow goes through annulus (between outer tube and inner tube) and heat transfers between two fluids now i want to model this by fluent and wanted to know how to choice viscous model for each region of fluid.
March 10, 2013, 06:16 |
Hi mozafarie,
thanks for giving more information. The working fluid is water. You need to specify the materials for the inner and the outer pipe. These materials are assumed to have the same density and heat capacity , but obviously different thermal conductivities. You need to change the thermal conductivities of the two pipe surfaces that you model as solid. In addition you use two different fluid b.c's i.e one for the cold fluid letu say 20°C Also turn on the energy equation option and choose the Reliazable k-epsilon turbulence model. You donot have to worry about how you specify the turbulent and laminar region this will be taken care by the boundary condition you specify and the eddy viscosity turbulence model will detect the laminar and turbulent flow internally. Do remember that you should use pressure based solver and specify the fluid material properties i.e water in your case properly like density, cp, thermal conductivity and viscosity. Define your first fluid inlet b.c for cold flow . That means velocity inlet and specify the velocity in the momentum tab followed by the choosing turbulent specification method as turbulent intensity and hydraulic diameter. Secondly choose the thermal tab and specify the temperature. Similar approach for the hot flow should be followed. For the walls of the pipe under the thermal tab you need to choose 0 W/m2. I hope this helps and wish you good luck. |
March 10, 2013, 06:56 |
ok thats good to know at least its helpful to you.
best of luck |
November 25, 2014, 01:58 |
#9 | |
manish sharma
Rep Power: 11 |
sir please help me |
Simulation of Steady-State Flow in a Constricted Tube with Laminar Viscous Model | rezatabe | FLUENT | 2 | September 9, 2011 12:49 |
how to solve a problem involving both laminar and turbulent flow | seefd | FLUENT | 1 | June 3, 2011 03:20 |
laminar or tubulent of gas flow in tube with different diameters? | Jiuan | FLUENT | 0 | December 20, 2010 21:17 |
turbulent and laminar flow modeling at same time | mdarzy | FLUENT | 0 | August 28, 2010 08:56 |
flow in annulus | M | FLUENT | 2 | July 16, 2007 09:49 |
