March 10, 2013, 07:20 |
How to view contour at each time step
Rep Power: 16 |
I have a question hope somebody answer me it. I need to view contours of pressure as monitor with each time step? is that possible?
March 10, 2013, 08:31 |
Alex
Rep Power: 46 |
Yes it is.
Under "calculation activities", you can enable autosaves at every timestep. |
March 10, 2013, 08:40 |
Rep Power: 16 |
Hi thanks for the reply. I want view it during run i not need to use auto-save i knew this method? I think viewing contour is possible by define commands but I do not know what I need to write in command line to view the pressure contours ? Thanks again?
March 10, 2013, 09:00 |
OJ
Rep Power: 20 |
Calculation activities >> Solution animations (bottom most option) >> Create
Define frequency of iterations/timestep, tick the contours and define them as you want. Note the window it is assigned to during the process. When you run calculation, and open the window that was assigned for the contours, you will see the contours updating. Cheers OJ |
March 10, 2013, 09:16 |
Rep Power: 16 |
Thanks i think this work.
AMI speed performance | danny123 | OpenFOAM | 21 | October 24, 2020 04:13 |
Time step size and max iterations per time step | pUl| | FLUENT | 33 | October 23, 2020 22:50 |
High Courant Number @ icoFoam | Artex85 | OpenFOAM Running, Solving & CFD | 11 | February 16, 2017 13:40 |
plot over time | fferroni | OpenFOAM Post-Processing | 7 | June 8, 2012 07:56 |
Could anybody help me see this error and give help | liugx212 | OpenFOAM Running, Solving & CFD | 3 | January 4, 2006 18:07 |
