Simulating Heat transfer in Two-Component internal mist cooling with thin film
Old   March 12, 2013, 17:18
Default Simulating Heat transfer in Two-Component internal mist cooling with thin film
Adarsh Gouda
AdarshGouda is on a distinguished road
How do i model this?! I have a tube with heat flux through its walls. The inside wall of the tube will always be covered with a thin evaporating sub-cooled liquid phase and there is nozzle generated spray (mist) as core. Two component = Non condensable gas + vapour component. So, the thin liquid film provides an evaporating medium while the fine mist core droplets continuously feeds the liquid film thereby preventing breakdown of the film (prevents dry-out). Scope : To study local heat transfer coefficients expecting high heat transfer co-efficient s due to phase change at the interface between liquid film and the mist core.
How do i start modelling this. Should i model the tube wall and liquid film and the mist core separately? or is there any other way??
AdarshGouda is offline   Reply With Quote
Water subcooled boiling Attesz CFX 7 January 5, 2013 03:32
Cooling Channel : Heat Transfer Gearb0x OpenFOAM Running, Solving & CFD 0 May 6, 2010 11:40
How can I increase Heat Transfer at Domain Interf? B.Simon CFX 3 October 28, 2008 18:53
UDF convective heat transfer correlations sarah FLUENT 0 March 29, 2007 09:52
free convection heat transfer from a heated horizontal surface through a liquid to a thin cooled fin Kaushik FLUENT 1 May 8, 2000 06:47
