how to improve the convergence of chemical reac.?
Old   April 12, 2006, 07:15
Default how to improve the convergence of chemical reac.?
lily
I have 14 species and 31 related reactions. Can anyone tell me if there is really chance that i would get an converged result? Can anyone give me some suggestions that i can follow to improve the convergence? Thanks in advance.
Old   April 12, 2006, 13:32
Default Re: how to improve the convergence of chemical rea
Allan Walsh
It may work. I'm modeling 12 to 15 species, with 10 to 12 separate reactions and convergence is not a problem. I'm modeling combustion cases with a modest number of cells (1/2 million) and enthalpy and radiation are the last to converge (and first to diverge).
I never bother with decreasing under-relaxation to less than 1 for species.
Old   April 12, 2006, 22:42
lily
thank you for your reply, allan. but now i am facing the problem of divergence already with only one reaction activated. can you give me some tips that how did you make it converge? thanks.
Old   April 13, 2006, 00:16
AkA
can u specify the type of model u have selected for ur reactions?
before activating the reaction(if it is combustion) try to run the case in cold flow , once this is converged activate the reaction.
Old   April 13, 2006, 16:47
Allan Walsh
lily - not sure about your problem, but we are modeling combustion in industrial boilers. So, our velocities are relatively low and pressure gradients small, but temperatures above 2000K exist. Divergence of multiple finite-rate/eddy dissipation reactions has never been a problem. Our grids our coarse - say 0.1 m - but the gradients in species concentration can be large.
We use the basic k-epsilon model for turbulence - are you using something more complicated? Does your case converge without the reactions? Or is heat generated so that the solution is trivial without the reaction?
You could set up a box or small 2-d case to check your reactions. In order to test sub-models, we have looked at cases with half-a-dozen species and a few reactions, to confirm that the finite rate/eddy dissipation model in Fluent matches up with laboratory data.
Good luck.
Old   April 13, 2006, 17:10
Default Thanks. Allan, my case is like this
lily
the very opposite to your case, my domain is very very small, a small nozzle, the grid is like 1e-7m, i have very high velocity and also very high temperature, the gas so is compressible. every gradient is huge, T, P. I didn't do detailed calculation to see how big the reaction would affect the whole calculation, but it's for sure not very convincing without it, the initial reactant has a mass ratio of 38% in total, and to break the bonds need energy. if the temperature field got affected by the reaction, so will the momentums.
Old   April 13, 2006, 17:15
Default thanks, AkA, i use finite-rate
lily
thanks, aka. i want to pull it out by modeling Species Transport and Finite-Rate Chemistry. I started from modeling only all the species transport and it converged well. but as soon as i added a reaction, it went wild.
Old   March 15, 2013, 11:41
Murdy Baskan
murdock88 is on a distinguished road
Do not forget to include radiation at combustion, because 500^4 small with respect to convective heat flux, but 1800^4 is high enough to decrease temperature of flame zones.
murdock88 is offline   Reply With Quote
Convergence Centurion2011 FLUENT 48 June 14, 2022 23:29
Force can not converge colopolo CFX 13 October 4, 2011 22:03
Improve simpleFoam convergence Daniele111 OpenFOAM Running, Solving & CFD 43 November 6, 2010 11:50
Convergence of CFX field in FSI analysis nasdak CFX 2 June 29, 2009 01:17
to improve convergence Mohamed FLUENT 0 May 14, 2003 05:43
