Strange error in ansys fluent
Old   March 11, 2017, 11:17
Default Strange error in ansys fluent
Sergio Contreras
sealcoga is on a distinguished road
Hi!
I have an error in ANSYS workbench at fluid flow (fluent).
When I start Simulation (Transient or Stationary), happens this :
First error :
Error: Cortex received a fatal signal (unrecognized signal).
Error Object: ()
Then start the simulation again without problems, but throw this message previously:
Error: cx-enable-item: wta[1](Widget)
Error Object: #f
Finaly , when the calculation finish without problems, or when I stop it, second Error:
Error: cx-show-item: wta[1](Widget)
Error Object: #f
Pleeeeees, what do I do for solve this error?
Thanks
PD: I do not know what to do, because this happens only for some models.
The same model, does not deliver said error, but if you change it of folder, then the error appear. It also does in old models that used to work well
It's strange
sealcoga is offline   Reply With Quote
Old   March 12, 2017, 21:00
Sergio Contreras
Hi!
First error :
Error Object: ()
Error Object: #f
Error Object: #f
Thanks
It's strange
Old   April 18, 2017, 00:16
Patel Brijesh
BRIJ is on a distinguished road
I got same error..sealcoga you solve this error...please help me
Sent from my Lenovo A7020a48 using CFD Online Forum mobile app
BRIJ is offline   Reply With Quote
Old   April 18, 2017, 01:35
Patel Brijesh
My project on shell and tube type condenser. In simularion choose Eulerian two phase model with k-e turbulent model. For cold water inlet give mass flow rate inlet condition and pressure outlet. Hot fluid also give mass flow inlet and pressure outlet condition. Here in condenser inlet and inside vacuum pressure so , at inlet given initial gauge pressure given -91000pa and outlet gauge pressure given -95000pa.
When I start Simulation (steady state), happens this :<br />
<br />
First error :<br />
Error Object: ()
Error Object: #f
Error Object: #
Please give some suggestion..thank you.
Old   May 23, 2017, 08:28
Default Consult
杨婷婷
Tingting Yang is on a distinguished road
Hi ,I'm a student who need use fluent.
I also have the problem. I don't know how to deal with it . I find that some simulation have the problem in a group of Simulation.But some simulation don't have the problem .They all use same model and similar case. I feel very puzzled.
Tingting Yang is offline   Reply With Quote
Using ANSYS Fluent 18.0 on workstations with multiple network cards and PBS Pro cheezum Hardware 0 February 28, 2017 10:23
How to combine ANSYS Fluent and Structural analysis? diwakar ANSYS 2 June 18, 2015 12:07
ANSYS and ANSYS Fluent Field85 ANSYS 3 May 17, 2015 16:21
few quesions on ANSYS ICEMCFD and FLUENT Prakash.Paudel ANSYS 0 August 12, 2010 12:07
Fluent & Ansys FSI architecture help DillonS FLUENT 1 April 7, 2010 16:00
