Home > Forums > FLUENT
Pressure Coefficient around cylinder
Old   March 18, 2013, 17:54
Default Pressure Coefficient around cylinder
Steve Mcharg
RealENG22 is on a distinguished road
Guys,
Doing a simple study to compare the Cp values to theta from a published paper.
I have used the same domain size/physical model/similar grid resolution/material and boundary conditions, however I am not getting the same value for Cp to theta.
Basically at the stagnation point (0 Degrees) I am getting a value of nearer 2... where experimental data, and the published paper suggest it should be 1.
I read somewhere that it may be an issue with the domain size.
Any thoughts?
Cheers
RealENG22 is offline   Reply With Quote
Old   March 18, 2013, 20:17
Stuart Buckingham
stuart23 will become famous soon enough
Pressure Coefficient greater than 1! You're breaking the laws of physics!
Set your reference values to something appropriate and try again.
Stu
http://bc247.wordpress.com
stuart23 is offline   Reply With Quote
Old   March 19, 2013, 16:59
Steve Mcharg
I know.. crazy eh!
Okay thanks Stu, I think my depth/length reference values may be incorrect.
I did manage to improve them slightly with a higher order numerical scheme, but still not right.
Cheers
Old   March 24, 2013, 09:56
Steve Mcharg
Actually.. do you know what I should use in my reference values for this type of domain (in terms of length, width, depth)? For the length I think I may have references the Cylinder Dia...
Thread Tools
Trackbacks are On
Pressure coefficient Giuseppe FLUENT 2 July 26, 2015 03:19
Coefficient DRAG and LIFT - Cylinder 3D Jwolf CFX 11 February 4, 2010 06:08
Pressure Coefficient Viscous Coefficient gunposer FLUENT 0 June 15, 2009 07:10
Hydrostatic pressure in 2-phase flow modeling (long) DS & HB Main CFD Forum 0 January 8, 2000 16:00
Problem in Result of the pressure coefficient Ken Choi Main CFD Forum 2 March 15, 1999 05:15
