August 3, 2005, 11:51 |
limiter
Does Fluent have the possibility to solve supersonic flow with a higher than 1st order accurate method (e.g. limiters like MinMod, van Albada, ...). Thanks, O. |
August 4, 2005, 00:00 |
Re: limiter
I did not find any. Check with support team for any add-on/way out if available.
Swarup |
March 19, 2013, 11:53 |
Murdy Baskan
Rep Power: 13 |
Limit minimum temperature, this improve supersonic flow convergence. I generally limit minimum temperature to 100. But if your mach number around 5 use must decrease minimum temperature to 50.
Display Modes | |
Ultimate Flux Limiter | gentela | Main CFD Forum | 1 | August 2, 2016 21:55 |
acces limiter for instance generated by vanLeer scheme | stevenvanharen | OpenFOAM | 0 | August 31, 2011 11:13 |
slope limiter and flux limiter ?? | Ameya J | Main CFD Forum | 1 | June 13, 2011 13:05 |
Definition of limiter function for central dirrerencing scheme | sebastian_vogl | OpenFOAM Running, Solving & CFD | 0 | January 5, 2009 12:08 |
Moment limiter in DG method. | jinwon park | Main CFD Forum | 0 | May 15, 2008 13:18 |
