-   -   Solution Initialization (http://www.cfd-online.com/Forums/fluent/115037-solution-initialization.html)
simulator March 22, 2013 07:21
I'm a new user of Fluent... In a steady simulation should the solution be independent of the initial conditions? I mean... depending on the solution initialization parameters a get different results... is that bad?
Regards.
oj.bulmer March 22, 2013 08:45
Bad initialization should result in longer convergence periods, but the results shouldn't be too different for different initializations, provided the boundary conditions and other settings remain the same.
OJ
flotus1 March 22, 2013 10:28
Originally Posted by simulator (Post 415669)
In most cases this means that the solution simply in not converged.
