January 20, 2015, 09:25 |
weight of air in cylinder
Rep Power: 11 |
I'm trying to simulate a injection of fuel to cylinder filled with air. I defined air as ideal gas. Temperature, pressure of air and volume of cylinder is known. Where to check what's the weight of air in cylinder? (in grams) Can fluent calculate it? Thank you in advance for your answers. Best regards. |
January 20, 2015, 10:16 |
Rep Power: 11 |
Go to results->reports->mass
January 21, 2015, 14:46 |
Rep Power: 11 |
Thank you Philus
flow over a cylinder urgent! | kevin | FLUENT | 8 | August 11, 2015 13:00 |
[blockMesh] Specifying boundary faces failes in blockMesh | blaise | OpenFOAM Meshing & Mesh Conversion | 0 | May 10, 2010 03:56 |
rotating cylinder using sliding mesh | Tim Daly | FLUENT | 1 | November 9, 2008 23:02 |
TRANSIENT HEAT & BOUYANCY IN CONFINED AIR | Carl | CFX | 1 | September 25, 2006 09:48 |
Turbulent steady flow around a circular cylinder | Mirek Kabacinski | FLUENT | 0 | July 23, 2003 18:40 |
