Double Tube Flow
1 Attachment(s)
hi;
i want to solve a natural convection in a double tube. water flows thorough the innert tube, and there is air in the annuli (and there is a natural convetion there). i can not set up the problem because there is an interface between two tubes. i send a figure in attachment about geometry and boundary conditions. if i select interface boundary condition for "interface" fluent says "WARNING: mesh check failed. "To get more detailed information about the mesh check failure increase the mesh check verbosity via the TUI command /mesh/check-verbosity. " if i select wall boundary condition for "interface" then fluent creats a interface-shadow. i select coubled under "thermal conditions" then define other boundary conditons. when i came the initialize section there is already "-1.#IND" in the velocity inlet and all zones. i delete that and put actual values. but fluent could not solve the problem, say "divergence detected in AMG solver: x-momentum" what can i do, how can i solve this problem i defined. thanks already sorry for poor english |
