March 27, 2013, 15:46 |
journal file - problem in initialization
Mohammad Reza Hadian
Rep Power: 17 |
i want to create a small journal file to
1- read case and data 2-initialize a surface (which is my air inlet and the name is air_inlet) 3- do the iteration 4- save the case and data 5- exit here is my journal file. but it does not work well and give me an error in initialization part. /file/read-case-data /home/hadian/1.cas /solve/initialize/compute-defaults/air_inlet /solve/iterate 10 /file/write-case-data /home/hadian/2 yes /exit yes /exit /quit |
March 28, 2013, 03:36 |
#2 | |
It seems that the command for 2 is missing, see below. I have a vague impression that FLUENT will initialize the flow automatically upon iteration. But you should try to manually add this line to check whether it makes any difference.
March 31, 2013, 06:38 |
Rep Power: 17 |
it seems that the command "/solve/initialize/compute-defaults/air_inlet" does not initialize on air_inlet surface. i do not know if the command is correct it something should be add to it!!!
April 1, 2013, 03:16 |
Rep Power: 17 |
this is the result:
> /solve/initialize/compute-defaults air_inlet invalid command [air_inlet] so there is something wrong! |
Display Modes | |
[swak4Foam] funkySetFields compilation error | tayo | OpenFOAM Community Contributions | 39 | December 3, 2012 06:18 |
1.7.x Environment Variables on Linux 10.04 | rasma | OpenFOAM Installation | 9 | July 30, 2010 05:43 |
DxFoam reader update | hjasak | OpenFOAM Post-Processing | 69 | April 24, 2008 02:24 |
DecomposePar links against liblamso0 with OpenMPI | jens_klostermann | OpenFOAM Bugs | 11 | June 28, 2007 18:51 |
PHI file structure | Eugene | Phoenics | 9 | November 2, 2001 23:00 |
