Convergence problems using extreme coefficient values like 1e-16 with porous jump
Like Tree2Likes
  • 1 Post By oj.bulmer
  • 1 Post By recepky
Old   April 2, 2013, 16:16
Default Convergence problems using extreme coefficient values like 1e-16 with porous jump
Recep Kaya
recepky is on a distinguished road
Hi fellow CFD users,
I want to model a cylindirical membrane(plenty of membranes) in a cross flow condition, and when I use permemability and C2 coefficients like 2e-16 for face permeability and 3e+12 for C2, problem diverges. I have to use this coefficients because membranes that I want to model, has kind of 0.0001m/s velocity at 100000Pa values. I am sure these coefficients are the reason behind the divergence.
How can I solve this divergence problem ?
Thanks
recepky is offline   Reply With Quote
Old   April 3, 2013, 11:07
OJ
oj.bulmer will become famous soon enough
As you guessed it, are you sure about these coefficients? How did you arrive at these values?
OJ
recepky likes this.
oj.bulmer is offline   Reply With Quote
Old   April 4, 2013, 10:23
Recep Kaya
hi oj
I arrive this values by plotting xy curve from my experimental data velocity and pressure drop, from the xy polynomial trendline excel generated the y=Ax2+Bx equation that I used to find C2 and alfa permeability coeffitions. I double checked everything that I do in excel. I am sure these coefficients is right. Because these coefficients belongs to a membrane that 0.5micrometer or even lower pore sizes. It has very low permeability compairing to normal filters.
shubhangini likes this.
Old   November 11, 2017, 02:12
Default same problem
shubhangini
shubhangini is on a distinguished road
Originally Posted by recepky View Post
hi oj
i too have the same problem.. it says workbench error.. but when i change face permeability to high value.. the simulation works smoothly.. i.e. my actual value is 1.52e-18 but i am using 1.52e+18 but this is of no use, not getting the correct radial velocity.
It's very disappointing.
shubhangini is offline   Reply With Quote
Momentum source coefficient and convergence meh CFX 9 October 12, 2020 08:37
Porous domain:Interfacial area density and heat transfer coefficient l.te CFX 2 May 17, 2014 23:45
Porous Jump fadiga FLUENT 1 May 5, 2012 09:30
Porous Jump Error Akim679 FLUENT 0 March 18, 2012 11:55
Porous jump in urban environment samygero FLUENT 0 February 14, 2011 18:26
