-   -   Help! 2 Dimensional Vertical Annuli Flow (http://www.cfd-online.com/Forums/fluent/115621-help-2-dimensional-vertical-annuli-flow.html)
bbasal April 3, 2013 11:21
2 Attachment(s)
hi,
I want to solve 2 Dimensional Annuli Flow. Dimensions are radial and axial. Water flows thorough the inner tube and there is air in the annulus. I want to solve heat transfer between water and air.
I draw the geometry 2D. A shadow wall
occurred between inner tube and annuli. and i can't solve the problem
2D Vertical Annuli Flow can be solved with Fluent
geometries are atteched
msaeedsadeghi April 4, 2013 05:36
It is normal. one wall is for the inner cylinder and the other wall is for the outer cylinder that are coupled together.
bbasal April 4, 2013 07:54
but when i try to initialize boundary contions i have some problems. when i try to specify "gauge pressure", "axial velocity", "radial velocity" and "temperature" there is already a value "-1.#IND". i change them with actual values but program dosen't work.
it says "Error: Divergence detected in AMG solver: x-momentum
Error Object: #f"
bbasal April 4, 2013 07:55
can i sent you the program file?
