Cell Zones
Like Tree1Likes
  • 1 Post By msaeedsadeghi
Old   April 4, 2013, 23:19
Default Cell Zones
Fraser
FraserK is on a distinguished road
Hi there,
(3d, pbns, VOF, spe, lam, transient)
I'm modeling fluid flows down a narrow pipe (fluids = water and air). In the "cell zone conditions" menu, the only zone I see is air [attachment1]. I believe I should see water and air.
Also: I'm trying to add surface tension effects between the walls and the water, but in the menu it appears I can only add the effects between the two fluids. Actually, with the options I've selected, I can't even find the option of setting a wall fluid angle interaction anymore...
I have some suspicion that these problems are related. Any ideas?
Thanks
FraserK is offline   Reply With Quote
Old   April 6, 2013, 09:11
SSL
msaeedsadeghi is on a distinguished road
I think it is surface tension between water and air, not water and wall.
go on phase interaction panel and set the water-air surface tension.
mix_mentzos likes this.
msaeedsadeghi is offline   Reply With Quote
Old   April 6, 2013, 20:33
Fraser
Good point, thanks! I made a slight mistake asking my question: If I want to set a contact angle (say at 90 degrees) with the wall for the water droplet, how do I do that? It doesn't appear I can set it for wall/water, even though in the manual it appears I can do this.
Make sense?
Old   April 7, 2013, 00:32
SSL
90 Degree....
just decrease gavity and increase water-air surface tension.
Old   April 9, 2013, 07:54
Fraser
Ok think I figured it out now! Thanks for your help! In case people are wondering, I was able to set the angle. In a VOF model, I selected "Wall Adhesion" in the momentum tab of the phase interaction. Then I set the angle in the boundary conditions tab.
[Other] how to extract cell zones by cgnsToFoam Ohbuchi OpenFOAM Meshing & Mesh Conversion 0 July 22, 2010 04:19
Cells with t below lower limit Purushothama Siemens 2 May 31, 2010 21:58
Warning 097- AB Siemens 6 November 15, 2004 04:41
Tracking/Modifying Cell Zones Greg Perkins FLUENT 1 November 6, 2000 23:35
