Home > Forums > FLUENT
Mach number
Old   April 9, 2013, 04:20
Default Mach number
Vaze
mvee is on a distinguished road
Hi
I need to use the mach number in further defining the total pressure for compressible flow modeling through UDF. How can I track the mach number?
Is there any macro? or Do I need to define explicitly by UDF?
Thank you
Mvee
mvee is offline   Reply With Quote
Old   July 11, 2014, 10:22
Aurelien Thinat
Aurelien Thinat is on a distinguished road
Hello Mve,
Did you find any solution to your problem ?
I'm trying to use F_MACH(f,t) and SV_MACH without any succes so far. Is there any trick to access the mach number at faces ?
Aurélien
Aurelien Thinat is offline   Reply With Quote
Old   July 14, 2014, 00:02
Vaze
Hi Aurelien
Based on the BC, I have calculated Mach number and then inserted in total temperature equation. This total temperature is then fed in BC panel. I have not used any UDF.
I believe the face values of Mach number are stored in temporary memory, hence could not be retrieved. You need to do linear interpolation to have face values. Is that clear?
Best wishes
Mvee
Thread Tools
Trackbacks are On
Mesh Refinement Luiz Eduardo Bittencourt Sampaio (Sampaio) OpenFOAM Mesh Utilities 41 January 17, 2013 03:43
mach number and selection of the fluent solver turbinesv FLUENT 4 April 24, 2011 00:14
Strong oscillation at transonic mach number martingariepy FLUENT 2 May 12, 2009 11:40
Trimmed cell and embedded refinement mesh conversion issues michele OpenFOAM Other Meshers: ICEM, Star, Ansys, Pointwise, GridPro, Ansa, ... 2 July 15, 2005 04:15
how calculate the density in low mach number? Juhee Lee Main CFD Forum 1 July 31, 1999 15:26
