-   -   the skin friction coefficient in Fluent (http://www.cfd-online.com/Forums/fluent/116142-skin-friction-coefficient-fluent.html)
GJ_hit April 13, 2013 23:27
I simulated the low-reynolds-number flow over airfoils, there is a seperation bubble on the upper surface of the airfoil.
The experiment data shows that the skin friction near the seperation bubble is negative. But the result I calcuate by the Fluent is positive.
I don't konw why this happened for there is already have the backflow in the seperation bubble near the surface.
Is it also a reason for the Fluent can't give a good prediticion of drag?
This question puzzle me for a long time. I need your help!
shuai_manlou April 13, 2013 23:47
The numerical result depends on several aspects, such as mesh topology, turbulent model, Yplus, you can check this parameters and try the process again. And you can find some tutorials on the airfoil on the Internet, check how the others settle it.
stuart23 April 14, 2013 20:23
Skin Friction is a vector quantity. Are you plotting the directional component of skin friction? If you are just plotting "Skin Friction Coefficient", you are plotting the vector magnitude which of course can never be negative.
Stu
ck3 April 15, 2013 08:08
Our friend "stuart23" says true.
I had the same problem for a turbulent separated flow. To get round this problem you must use the equation of Skin Friction Coefficient given in the help:
file:///C:/Fluent.Inc/fluent6.3.26/help/html/ug/node1219.htm#217810
Good luck.
