April 16, 2013, 09:34 |
How to model a turbulent nozzle
Hi there,
i got a problem modeling a turbulent nozzle: blue is the inlet with BC pressure inlet 240 00 000 Pa. red is the outlet with BC pressure outlet 100 000 Pa. material: destiny 1860 kg/m3 viscosity 5 kg/m*s (very high) i choose the rng k-epsilon modell but the volume flow is to low. my question is if its the right model? which model do you choose for this problem? which wall function should i use? |
Stability problem due to turbulent dispersion force in a subcooled boiling model | Edy | OpenFOAM | 7 | August 10, 2011 12:00 |
Turbulent SST model | fergal | CFX | 13 | November 2, 2010 18:15 |
Low Reynolds k-epsilon model | YJZ | ANSYS | 1 | August 20, 2010 13:57 |
difference of the laminar and turbulent model | duaiduaihu | FLUENT | 0 | August 13, 2010 23:40 |
Two-layer turbulent model | maolongliu | OpenFOAM Programming & Development | 0 | July 27, 2010 11:40 |
