March 15, 2013, 14:04 |
Particles not been tracked
Mack Johnson
I am trying to simulate a human head being sneezed on. My particle inlet is set 0.5m away from the human mouth, with a 20m/s velocity. The partilce injection is a surface injection. the max number of steps is set at 10,000,000. I have meshed the mouth appropriately. The problem I am encoutering is that the partilces tracks are not picked up. I have set it so 10,000 particles are to be sprayed on to the human head. Though when i run the simulation and go to the particle tracking results only 10% of the particles I input are being tracked. Of those tracked, the majority are also incomplete. Can anyone please help me? Thankyou, Mack |
March 15, 2013, 14:58 |
A-A Azarafza
Rep Power: 14 |
Hi mack
The success in DPM model to track particles needs somehow trick. First you gotta receive a converged single phase solution which is either gas or liquid, then injecting your particles. I had your problem once, but I did it myself in my case. Stick in your mind that you need to adjust both time step and step size correctly to be able to track all particles. The first thing is that you need to increase the maximum number of steps. There's a rule of thumb, I recall that the multiplication of the numbers of cell in flow direction by step size should be equal to Max number of iteration. Hope it help |
April 27, 2013, 06:02 |
sajeesh
Rep Power: 13 |
hello....
There's a rule of thumb, I recall that the multiplication of the numbers of cell in flow direction by step size should be equal to Max number of iteration. i am not getting that. How i get the number of cells in the flow direction. two doubts also what is DPM concentration It is show that Residence time *mass flow rate of particle /cell volume What is the meaning of residence time and cell volume... How exactly i can select certain number of particle in the domain |
Display Modes | |
how to determine the number of particles injected. | welch | FLUENT | 2 | January 18, 2024 05:08 |
UDF for deleting particles in DPM | imanmirzaii | Fluent UDF and Scheme Programming | 12 | November 25, 2020 20:27 |
trying to simulate two-phase jet flow with particles in surface injection | ajkratos | FLUENT | 5 | March 3, 2015 22:33 |
Straight through cyclone with particles | rogerhoffmann | CFX | 1 | May 21, 2012 19:42 |
particles model | ati_ros61 | FLOW-3D | 3 | December 6, 2009 17:03 |
