-   -   How can you tell at which point the flow transitioned from laminar to turbulent on an (http://www.cfd-online.com/Forums/fluent/116380-how-can-you-tell-point-flow-transitioned-laminar-turbulent.html)
aditipatel7 April 17, 2013 23:07
1 Attachment(s)
ok I just have one basic question here... How can you tell at which point the flow transitioned from laminar to turbulent? I know we can do u+ vs y+ for a flat plat boundary layer profile. But for an airfoil/turbine cascade that is curved...what is the method? My geometry is attached below
oj.bulmer April 18, 2013 00:54
The shear in laminar boundary layer is smaller while that in turbulent one is larger. How about plotting a skin friction coeff along the curved wall? A big jump in it should indicate the transition.
OJ
ram_call April 18, 2013 03:34
there is no laminar flow in fact and all turbulent models can solve so called laminar flow, so u should consider all field as turbulent specially in geos like turbines!
Far April 18, 2013 04:56
You can plot intermittency, turbulent kinetic energy, turbulence intensity and integral parameters.
I don't know how you can use skin friction to infer transition, may it is a good indicator of separation but have no idea about transition. I'd interested to find out that how we can use skin friction...
oj.bulmer April 18, 2013 07:40
The approach I mentioned is, of course, just one of the many popular ways of judging the transition. When there is enough motivation for transition, the Tollmien-Schalichting (TS) waves are developed in the flow which typically are 2D. The waves produce disturbances and slowly they grow into 3D structures giving rise to local vortices etc creating a high shear region.
Skin friction coefficient is of course a measure of this shear. Hence its plot on streamwise direction provides a point where the skin-friction shoots up, an indication of transition.
OJ
Ref:
Castelli, M. Raciti, G. Grandi, and E. Benini. "Numerical Analysis of Laminar to Turbulent Transition on the DU91-W2-250 airfoil."
Hanjalic, K., Y. Nagano, and S. Jakirlic. "The application of laminar kinetic energy to laminar-turbulent transition prediction."
Johansen, Jeppe, Jens N. S-oacute, and rensen. "Prediction of laminar/turbulent transition in airfoil flows." Journal of aircraft 36.4 (1999): 731-734.
Far April 18, 2013 08:59
can you send these papers to turboenginner@gmail.com
oj.bulmer April 18, 2013 23:22
Sent, cheers
OJ
Far April 18, 2013 23:53
Oj
Thanks a lot.
