April 18, 2013, 03:06 |
Radial Turbine Analysis B.C Problem
Yang Ju-Suk
Im now research about radial turbine.
And using Fluent for CFD analysis. I use MRF model under Density Base SST K-w. and initial condition are below inlet total pressure : 998430 pa inlet total temperature : 358K inlet mass flow rate : 0.402 kg/s outlet total pressure : 166405 pa outlet total temperature : 230K So, i use pressure inlet and pressure outlet as B.C of this model. Put inlet total pressure and temperature in pressure inlet, and put outlet total pressure and temperature in pressure outlet. Furthemore, i put 0 pa in operation pressure. But in has not conversing. What is problem of this model? I have not enough time for submit my paper TT Please help me. |
Axial Flow Turbine Problem | Manish | FLUENT | 1 | February 14, 2017 03:46 |
Radial turbine problem | ingmecc | FLUENT | 3 | January 22, 2012 21:26 |
Turbine: Transient Simulation Problem | John C. | CFX | 7 | December 5, 2011 08:31 |
radial turbine flow analysis | ME | FLUENT | 0 | July 2, 2007 09:18 |
Usage of Star-CD in analysis of Wind Turbine | Manabendra M. De | Siemens | 5 | January 6, 2007 23:42 |
