Fluent Tui Command for transient
Hello All,
I have found the fluent tui guide somewhat difficult to use because it often tells you what a command does, but not the subsequent path to get there. I searched through this guide and have not found how to transition a simulation from steady state to transient. This is important for initializing when using the automated parameterization. Has anyone come across this? Thanks in advance! |
TUI code to set transient solver
;; To turn on unsteady first order
/define models unsteady-1st-order? yes ;; To turn on unsteady 2nd order /define models unsteady-2nd-order? yes ;; To turn on steady-state solver /define models steady? yes ;; To iterate with steady state solver (10 iterations) (iterate 10) ;; To iterate with unsteady solver (10 time steps, with 20 maximum iterations per time step) (physical-time-steps 10 20) Hope this helps, Bill Wangard, Ph.D. Engrana LLC |
Thanks!
That is extremely helpful! Thank you very much. I am so very glad we have an active and helpful community
For a reason that I ignore, the command 'dual-time-iterate' doesn't work when I open a transient case, load data and try to iterate further. Nothing happens. Is this a bug? Thanks. |
Use
/solve/iterate 200 /solve/dual-time-iterate 200 20 instead. I have never been able to appreciate the merits of LISP. |
Could you please tell how to write for setting pseudo transient case using TUI?
