-   -   How to set the boundary condition of Pressure Outlet (http://www.cfd-online.com/Forums/fluent/116471-how-set-boundary-condition-pressure-outlet.html)
justeyong April 19, 2013 17:29
Hi there,
I have a simple geometry, which is a vertical tube. I know the inlet velocity and , and the pressure at outlet.
The turbulent model is standard k-epsilon. I set the inlet as velocity inlet with values of U, P, k, and epsilon.
However, when I set the outlet boundary condition, Pressure Outlet, the only thing I know is the pressure.
My question is how to (or do I need to) set the backflow turbulent k and backflow turbulent epsilon?
valio April 20, 2013 04:06
Set the same values of k and e for your pressure outlet condition.
You can launch your computation, save results and launch a computation with other values of k and e and see the influence, but I think it does not really matter.
Valio
Far April 20, 2013 09:58
Originally Posted by justeyong (Post 421847)
Hi there,
These values are used only when there is reverse flow I guess. Otherwise only pressure is required at outlet.
justeyong April 20, 2013 14:31
Originally Posted by valio (Post 421908)
Valio
Thanks very much!
