Question about Pressure Field in ANSYS Fluent |
March 3, 2016, 13:01 |
Jian Feng
Rep Power: 10 |
Hi, I am a beginner of ANSYS Fluent, and looking for help.
I have got a question about setting a oscillating pressure field in ANSYS Fluent. Basically, I am trying to simulate a bubble oscillation behavior in a sinusoidal acoustic pressure field. It looks like the 'floating operating pressure' can only set a steady pressure field. What I need is a pressure field applied to all of the domain, but with a time depended function. Does any one have the idea how to make it? Thanks. |
March 6, 2016, 10:23 |
Lucky
Rep Power: 65 |
You could just specify a time-dependent pressure at your domain boundaries. Pressure inlet or outlet. Run an incompressible or constant density simulation (very non-physical) and that will give you the infinite sound speed needed to achieve a uniform pressure field.
March 6, 2016, 20:35 |
Jian Feng
Rep Power: 10 |
Thanks for your information! I am just a beginner...so I have one more question. What should I do after I get the sound speed? How to put this parameter into fluent?
March 6, 2016, 22:56 |
Lucky
Rep Power: 65 |
Why do you care what the sound speed is?
If you want a uniform pressure field, the only way to achieve that is to have an infinite sound speed which can only be done via an incompressible or constant density substance. The sound speed is specified by your equation of state. |
March 7, 2016, 10:48 |
Jian Feng
Rep Power: 10 |
Thanks for your reply. I have a stupid question. So basically, the acoustic field is just a result of pressure inlet/outlet boundary condition? I should only give the oscillating pressure to boundary instead of the whole domain (bubble and surrounding fluid)?
March 7, 2016, 12:38 |
#6 | |
Lucky
Rep Power: 65 |
If you want to impose an oscillating pressure field to the whole domain, you no longer have a boundary value problem and the Navier-Stokes equations are no longer applicable. This is a low-order model and has a completely different set of governing equations. Differential equations can be boundary value problems or initial value problems, where you specify constraints at the initial time or at spatial ends of the problem. You cannot specify a time-dependent pressure field (you cannot put constraints on the interior). An incompressible substance will react instantaneously to changes in pressure at domain boundaries. If you want finite speed of sound (then you should use a better equation of state). |
March 7, 2016, 14:42 |
Jian Feng
Rep Power: 10 |
I am pretty clear what to do now. Thank you so much!!!
static vs. total pressure | auf dem feld | FLUENT | 17 | February 26, 2016 13:04 |
How to combine ANSYS Fluent and Structural analysis? | diwakar | ANSYS | 2 | June 18, 2015 12:07 |
The fluent stopped and errors with "Emergency: received SIGHUP signal" | yuyuxuan | FLUENT | 0 | December 3, 2013 22:56 |
Surface Pressure Gradient at Heaving Airfoil in ANSYS Fluent | saifullahkhalid | FLUENT | 0 | November 11, 2013 04:17 |
what the result is negatif pressure at inlet | chong chee nan | FLUENT | 0 | December 29, 2001 05:13 |
