Home > Forums > FLUENT
energy source term for phase change
Old   April 21, 2013, 14:18
Default energy source term for phase change
mhdmk is on a distinguished road
hi everyone
i'm simulating a converging-diverging nozzle saturated water enter and because of pressure drop flow changes to two phase and the temperature decrease.for evaporation & condensation i use evaporation-condensation model in ansys fluent 13 with T_sat varying by pressure and i use a source term to add latent heat to energy equation and i use mixture model but when i run the case the fluent says :
FLUENT received fatal signal (ACCESS_VIOLATION)
1. Note exact events leading to error.
2. Save case/data under new name.
3. Exit program and restart to continue.
4. Report error to your distributor.
Error Object: #f
here is my udf's:
#include "udf.h"
real T,p;
return T;
DEFINE_SOURCE (phase_change,c,t,dQ,eqn)
real a,b,Tsat,T,h,Q,p1,m_net;
Thread **pt = THREAD_SUB_THREADS(tm);
Thread *tp = pt[0]; /*primary phase*/
Thread *ts = pt[1]; /*secondary phase*/
if(200.<T<272.7) h=2835000.; /* latent heat(j/kg)*/
if(272.7<T<500.) h=(-0.004*pow(T,2.)+0.492*T+2681.)*1000.;
m_net=(a*b*(T-Tsat)/Tsat) /*mass transfer(kg/m3s)*/
if(272.7<T<500.) dQ[eqn]=a*b*(h/Tsat+(-0.008*T+.429)*(T-Tsat)/Tsat);
else dQ[eqn]=a*b*h/Tsat;
return Q;
mhdmk is offline   Reply With Quote
Old   May 31, 2013, 11:24
Mahboobe Mahdavi
Mahboobe365 is on a distinguished road
Hi can I have your email address? I am working on evaporation condensation problem I have some question.
Mahboobe365 is offline   Reply With Quote
Old   June 3, 2013, 14:54
what is your question ?
Old   November 26, 2013, 13:50
meisam1 is on a distinguished road
Has your problem solved Mr koochaki?
meisam1 is offline   Reply With Quote
Thread Tools
Trackbacks are On
Error bulding swak4Foam sfigato OpenFOAM Installation 18 August 22, 2013 12:41
pisoFoam compiling error with OF 1.7.1 on MAC OSX Greg Givogue OpenFOAM Programming & Development 3 March 4, 2011 18:18
UDF for energy source João Fernandes FLUENT 4 October 17, 2008 04:53
UDFs for Scalar Eqn - Fluid/Solid HT Greg Perkins FLUENT 0 October 11, 2000 03:43
linearization of radiative energy source term Nuray Kayakol Main CFD Forum 0 May 7, 1999 08:11
