-   -   Error: Floating point error: overflow (http://www.cfd-online.com/Forums/fluent/116777-error-floating-point-error-overflow.html)
sezar April 25, 2013 02:40
Hi everyone
I have a question
i am simulation two phase flow at fluent
air=primary phase----------water liquid=secondary phase
air velocity=10m/s &water velocity=1m/s
i am use the schiller naumann for drag
and slip velocity i am use manninen - et-al
but when i am run simulation This message is appear
((Error: Floating point error: overflow))
can some one help me ?
oj.bulmer April 25, 2013 04:25
Are you sure about the phases are not other way around, ie Water being primary and air being secondary?
OJ
sezar April 25, 2013 05:35
hi
i am sure
air carried water droplet toward filter
air= primary phase=i am sure
vasava April 25, 2013 05:51
There can be several reasons for the floating point error. If your case is transient than try reducing the time step. A relatively bigger time-step can be the reason behind this error.
I hope you have fine mesh else that could also be another problem.
