Algorithm to create chemical reactor network zones from flow field
Old   April 25, 2013, 05:54
Default Algorithm to create chemical reactor network zones from flow field
Ananthakrishnan.A.S
Ananthakrishnan is on a distinguished road
Send a message via Skype™ to Ananthakrishnan
I am trying to understand the process of generating an algorithm for splitting the flow field (obtained through CFD ) into homogeneous zones to be used by chemkin for processing the pollutants.
I have so far understood the required input variables to be processed in the algorithm but what i dont understand is the output of the file.
How do i actually split the physical mesh into zones!!(or should i just continue by splitting the mixture fraction into zones without dealing with the actual mesh). This is more of a problem because i dont know how chemkin works and i am yet to understand that as well!!
if anybody can shed any kind of light upon this topic (help files or logic behind splitting the zones) i will be really thankful.
I have the fluent cas and data files, if required.
Thanks a lot
Ananthakrishnan is offline   Reply With Quote
unexpected flow speeds within porous zones MasterCooler OpenFOAM 11 May 2, 2012 07:48
chtMultiRegionFoam - exchange data between flow field and temperature phsieh2005 OpenFOAM Running, Solving & CFD 0 February 7, 2012 09:16
rerun with same flow field, different fluid props Tim Phoenics 0 March 3, 2004 14:51
Flow visualization vs. Calculated flow patterns Francisco Saldarriaga Main CFD Forum 1 August 2, 1999 23:18
