Home > Forums > FLUENT
Low Pressure Surface Coverage
Old   April 25, 2013, 12:00
Default Low Pressure Surface Coverage
Natali
Natali_Beginner is on a distinguished road
Hello guys,
I am recently start working with FLUENT, but I have been working for 10 years in chemistry and combustion. So, this question that I am asking relates just to the FLUENT manipulation.
I am simulating combustion in low pressure. So, surface coverage is low in that pressure that seems reasonable.
However, its low rate value in FLUENT doesn't make sense. In fact, FLUENT doesn't have progress in that after some iterations and the surface coverage remains unchanged.
Do you have any suggestion how to get rid of that?
I am entering some coverage-dependent reaction parameters but it doesn't work.
I really appreciate if you help me since I am so stuck on that
Thanks,
Natali
Natali_Beginner is offline   Reply With Quote
Old   April 25, 2013, 19:46
Natali
Hey Guys,
I am really praying somebody helps me from this annoying problem.
Thanks,
Natali
Old   April 26, 2013, 14:32
Natali
Any Help?
I am really in problem.
Old   April 26, 2013, 14:39
Parisa
Parisa_Khiabani is on a distinguished road
Hey Natali,
There is an option in the surface chemistry as coverage dependent reaction. Did you check that?
By default, its values are zero. maybe you want to change them to a realistic value.
Did you check the Knudsen number in your problem? Be careful that the knudsen number not become very high, say 0.1
Parisa
Parisa_Khiabani is offline   Reply With Quote
Old   April 26, 2013, 14:50
Natali
Thanks Parisa,
Yes, I tried that too. However, it doesn't work although at the beginning just a little bit more progress in coverage is seen, but it will be stopped.
the Knudsen number is in the range of continuum approach. So it shouldn't have any problem.
I am really confused and exhausted about this problem.
Natali
Old   April 26, 2013, 14:56
Parisa
So, do you have any estimate about the real times or values?
The reactions reach to equilibrium soon in low pressure and maybe you get correct results.
Idk
Old   April 26, 2013, 15:16
Natali
I don't have exact values to compare.
But I know that the surface coverage should keep changing.
Old   April 26, 2013, 15:21
Parisa
Can you send me your case?
Old   April 26, 2013, 15:23
Parisa
I sent you already my Email.
Old   April 26, 2013, 15:26
Natali
Check your Email, please.
Thanks,
Natali
Old   April 28, 2013, 02:19
Natali
Hello guys,
I am seriously praying somebody can help me to solve this issue. This seems very annoying and boring.
Thanks,
Natali
Thread Tools
Trackbacks are On
Pressure velocity decoupling in low mach compressible flow Meeranandan Main CFD Forum 0 February 13, 2013 04:47
Layers don't fully surround surface EVBUCF OpenFOAM Native Meshers: snappyHexMesh and Others 14 August 20, 2012 04:31
Pulsatile pressure inlet with pressure outlet a.lynchy FLUENT 3 March 23, 2012 14:45
[ICEM] Problems with coedge curves and surfaces tommymoose ANSYS Meshing & Geometry 0 August 5, 2011 16:02
Pressure BCs or Periodic BCs for model of frost on vertical surface? andy.eco FLUENT 2 March 26, 2010 03:02
