April 26, 2013, 09:31 |
Sphere-Fluid Heat Transfer
Elina Mathew
I have a sphere fluid flow in a channel. I want to study conduction in the sphere 1) I create 2 zone ( 1 fluid zone and 2 for solid zone (sphere)). 2) I set all interfaces between solid and fluid to wall. 3) After exporting mesh to fluent, I see a -shadow boundary condition of type wall for each interface wall. 4) I enable heat equation. (knowing that the two wall are coupled) 5) Fluid flowing at 0.0001m/s water,370K 6) Sphere (copper) 300K initial temp.2spheres attached together.... Grid convergence has to be done...so Steady state simulation was tried...though the solution converges.... the problem after running simulation there no transfers conjugate between fluid and solid the temperature of solid remains stable (initial temperature). Please help me ..give me suggestions regarding the Setup of case esp boundary conditions... Thanks in advance...... |
April 27, 2013, 10:28 |
Elina Mathew
I used pressure velocity coupled-SIMPLE
and all second order upwind.. |
April 28, 2013, 20:31 |
Elina Mathew
Hi
Yes I tried that also..still the temperature at that outlet seems to be the same as 370 or 369.99 SO it means there is no conduction happening in the sphere...I mean the temperature is not transferred to the sphere from the fluid...What could be the reason..Any guess and can you tell what exactly this steady state will do in this kind of simulation....?? |
Heat transfer (conduction) between two pipes | shields | FLUENT | 14 | February 3, 2016 07:45 |
Natural convection - Inlet boundary condition | max91 | CFX | 1 | July 29, 2008 20:28 |
urgent: heat transfer fluid to solid | marco | FLUENT | 1 | October 28, 2005 22:17 |
