-   -   Laminar simulation with Simple Algorithms and Coupled Algorithms. (http://www.cfd-online.com/Forums/fluent/116876-laminar-simulation-simple-algorithms-coupled-algorithms.html)
lienien April 26, 2013 18:46
Hello, everyone
I am doing the laminar simulation of channel flow. I use pressure-based Simple Algorithms and Coupled Algorithms to simulate the flow (Reynolds number is 1000 and 2000) respectively. But there is velocity fluctuation in the case of Re=2000, Simple Algorithms. The flow in all the other three cases seems stable, including the case Re=2000, Coupled Algorithms. Why? Is this a sign of flow transition? I know it is difficult to simulate the transition with Fluent if you do not know the transition point. But how to explain this phenomenon? Thanks.
oj.bulmer April 30, 2013 09:55
If you are saying coupled algorithms are more stable, then this is not exactly a news! The transition typically is handled better by transition turbulence models or even Low Re models, have you tried them?
OJ
lienien April 30, 2013 10:54
Are there some turbulent transition model in Fluent? What's your meaning of Low Re model? Thanks for your answer.
blackmask April 30, 2013 11:02
There are two transition models, transitional sst model and k-kl model. The low reynolds model needs to be activated via the TUI, something like
/define/models/viscous/turbulen-expert
You should check the user's guide yourself.
However, personally I insist that the way of p-v coupling should not alter the physics of the flow, be it laminar, transitional or turbulent. You should try reducing the URF for the case of Re=2000 with Simple algorithm.
lienien April 30, 2013 11:15
Thanks. I will try them right now.
