how to get distance between particle and center of channel
Old   April 26, 2013, 22:27
Default how to get distance between particle and center of channel
harry
rystokes is on a distinguished road
Hello everyone,
I'm interested in calculating the distance between particles and the center of channel by UDF, because I want to know the location of particle in the cross section of channel to calculate the lift coefficient. I know we can use POS_P(p) to get the position of tracked particles, however, since my model is a planar spiral channel with fixed width and height, for a certain particle, the coordinate of the corresponding vertcial centre plane of the channel keep changing. I just wonder if there is any approach to solve the problem. Thank you very much for your kind help in advance.
Hanks
rystokes is offline   Reply With Quote
Particle impaction on surface Julian K. CFX 10 January 12, 2012 09:49
distance between particle and wall Worth FLUENT 2 June 13, 2009 03:04
Iclude particle diameter effect in wall? yueroo FLUENT 0 April 14, 2001 03:56
Particle Trajectory calculation when particle hit yueroo FLUENT 2 February 28, 2001 04:26
Normal distance from a particle to a surface Newbie FLUENT 1 February 26, 2001 12:44
