Continuity Residual Does Not Converge
Like Tree3Likes
  • 3 Post By oj.bulmer
Old   April 29, 2013, 10:52
Default Continuity Residual Does Not Converge
victorz is on a distinguished road
Hi all,
I'm solving a 3D compressible flow in a channel with perforated plates. I modeled the actual holes in the plates, rather than using the porous media approach.
I'm using a steady state solution, coupled scheme with quasi-transient approach.
After about 2500 iterations all my surface monitors have reached a steady state, the mass flow rate is perfectly balanced between the inlet and outlet, and all my residuals have converged, except for the continuity.
The continuity residual is reducing but at a very very slow pace, and at this stage it is ~6e-m.
Can I consider the solution converged? Should I continue the run (maybe beyond 10000 iterations)? In case the residual does not go below 6e-3, what should I do to obtain convergence?
Thanks!
victorz is offline   Reply With Quote
Old   April 29, 2013, 11:02
OJ
oj.bulmer will become famous soon enough
Have you checked the mass imbalance?
OJ
oj.bulmer is offline   Reply With Quote
Old   April 29, 2013, 11:05
Yes I did, the mass in/out is perfectly balanced, within 0.1% error.
Old   April 29, 2013, 11:50
OJ
If solution is mesh independent, all the monitors are flat, mass imbalances are small enough to your liking, and there is a monotonicity in your residuals, then I don't see a reason you should be worried about. I have observed that even within 2-eqn models, Realizable models reduces continuity to much smaller values than RNG. This must just be a numerical artifact!
OJ
RodriguezFatz, shyamal and toraman like this.
Old   April 30, 2013, 01:49
Thanks a lot for the advice!
convergence, fluent 14, residual
pimpleFoam: turbulence->correct(); is not executed when using residualControl hfs OpenFOAM Running, Solving & CFD 3 October 29, 2013 08:35
How to write k and epsilon before the abnormal end xiuying OpenFOAM Running, Solving & CFD 8 August 27, 2013 15:33
calculation stops after few time steps sivakumar OpenFOAM Running, Solving & CFD 7 March 17, 2013 06:37
Orifice Plate with a fully developed flow - Problems with convergence jonmec OpenFOAM Running, Solving & CFD 3 July 28, 2011 05:24
Could anybody help me see this error and give help liugx212 OpenFOAM Running, Solving & CFD 3 January 4, 2006 18:07
