Seeking seriou help Fluent problem..!!!
Old   May 4, 2013, 05:33
Default Seeking seriou help Fluent problem..!!!
Sumeet Kotak
sumeet kotak is on a distinguished road
Hello friends,
I am using Ansys Fluent for my simulation and simulating Electron Beam Physical Vapor Deposition System (EB-PVD) to find out coating thickness deposited over the substrate inside the chamber.I am using species transport model with volumetric reaction.
For better improvement of coating quality we are creating vacuum inside the chamber (0.005 pa) in experiment so I need to create vacuum inside the chamber in my simulation so which kind of pressure condition should I provide for pressure outlet BC and for operating pressure.
My geometry dimensions are vertical cylinder of height 750mm and radius 225mm and horizontal cylinder is connected with vertical cylinder at height of 200mm from bottom and another end is connected with vacuum pump creating vacuum of 0.005 pa.
The dimensions of horizontal cylinder: 200mm length 50mm radius
Looking for you positive replay,
sumeet kotak is offline   Reply With Quote
fluent parallel problem in win7 x64 system dunga82 FLUENT 8 April 19, 2012 20:23
[ICEM] ICEM CFD boundary conditions conversion to Fluent problem kalyangoparaju ANSYS Meshing & Geometry 0 October 30, 2011 23:40
Problem in IMPORT of ICEM input file in FLUENT csvirume FLUENT 2 September 9, 2009 01:08
Fluent boundary conditions problem bobo FLUENT 2 July 3, 2009 06:28
Fluent parallel license problem brothershuai Main CFD Forum 0 July 1, 2009 15:41
