May 4, 2013, 06:33 |
Seeking seriou help Fluent problem..!!!
Sumeet Kotak
Hello friends,
I am using Ansys Fluent for my simulation and simulating Electron Beam Physical Vapor Deposition System (EB-PVD) to find out coating thickness deposited over the substrate inside the chamber.I am using species transport model with volumetric reaction. For better improvement of coating quality we are creating vacuum inside the chamber (0.005 pa) in experiment so I need to create vacuum inside the chamber in my simulation so which kind of pressure condition should I provide for pressure outlet BC and for operating pressure. My geometry dimensions are vertical cylinder of height 750mm and radius 225mm and horizontal cylinder is connected with vertical cylinder at height of 200mm from bottom and another end is connected with vacuum pump creating vacuum of 0.005 pa. The dimensions of horizontal cylinder: 200mm length 50mm radius Looking for you positive replay, |
fluent parallel problem in win7 x64 system | dunga82 | FLUENT | 8 | April 19, 2012 21:23 |
[ICEM] ICEM CFD boundary conditions conversion to Fluent problem | kalyangoparaju | ANSYS Meshing & Geometry | 0 | October 31, 2011 00:40 |
Problem in IMPORT of ICEM input file in FLUENT | csvirume | FLUENT | 2 | September 9, 2009 02:08 |
Fluent boundary conditions problem | bobo | FLUENT | 2 | July 3, 2009 07:28 |
Fluent parallel license problem | brothershuai | Main CFD Forum | 0 | July 1, 2009 16:41 |
