divergence due to high pressure drop in two-stroke scavenging |
May 16, 2013, 05:29 |
Alessandro Renna
I'm working about a model in fluent of two-stroke engine uniflow scavenging, with dynamic meshes of piston and exhaust valves. The start of my simulation is the exhaust valves opening (lift from 80 CAD to 250 CAD); near BDC, the piston opens 14 ports of intake (opened from 115 CAD to 245 CAD). I initialize my cell zones with exp. data, so I have high pressure and temperature in cylinder (18 bar, 1600 K) and lower conditions in intake volume and exhaust pipes (about 2.5 bar). This high pressure drop between the volumes makes the simulation crash/diverge at first 2 iterations. If I simulate the same model with lower pressure drop (e.g. 0.03 bar and not 15.5 bar!!!) there's no problem. Can anybody help me? Thanks. |
May 16, 2013, 08:58 |
Cristiano
Rep Power: 13 |
do you try simple model calculation? Good Luck! |
May 16, 2013, 09:52 |
venki
Rep Power: 14 |
u can slowly rise the pressure after convergence
0.03 to 0.1 similar like |
May 17, 2013, 10:47 |
Alessandro Renna
how can I do this?
Thx |
May 17, 2013, 15:13 |
venki
Rep Power: 14 |
Please send some figure to understand your problem....
slowly increases input values from low values |
divergence amg, dynamic mesh, high pressure drop, scavenging |
Pressure Drop Calculation | mk_mard | STAR-CCM+ | 3 | August 29, 2011 02:06 |
Pressure drop? | Munni | FLUENT | 4 | March 25, 2010 14:21 |
Pressure drop of valve with valve opening of 30% | elogesh | Main CFD Forum | 2 | January 5, 2007 12:30 |
Neumann pressure BC and velocity field | Antech | Main CFD Forum | 0 | April 25, 2006 02:15 |
Hydrostatic pressure in 2-phase flow modeling (CFX4.2) | HB &DS | CFX | 0 | January 9, 2000 13:19 |
