DPM particle tracking
Old   May 12, 2013, 02:29
Default DPM particle tracking
sajeesh
sajeesh is on a distinguished road
Hi
I read DPM particle tracking will consider the particle as a point.so my question is whether this model is sufficient to track the particle which driven through the fluid domain by drag force only.. whether it will give the proper velocity change happened to the particle when dragging by the fluid.
I need to calculate the what will be the steady state velocity of the particle even if the particle is introduced in the fluid domain at velocty of zero velocity.will acheive the maximum velocity of fluid or the more than the maximum velocity of the fluid.
thanks in advance
sajeesh
sajeesh is offline   Reply With Quote
Ubuntu 12.10 + openfoam2.2.0 ==> paraview error message peteryuan OpenFOAM Installation 6 August 18, 2013 18:00
DPM particle traCKING sajeesh FLUENT 1 April 27, 2013 23:12
DPM particle tracking in stirred tank parisa- FLUENT 1 August 7, 2012 12:03
DPM particle tracking parisa- Main CFD Forum 2 June 15, 2011 05:12
DPM UDF particle position using the macro P_POS(p)[i] dm2747 FLUENT 0 April 17, 2009 01:29
