coal combustion
Old   May 16, 2013, 11:25
Default coal combustion
semo is on a distinguished road
I am modeling coal combustion with non-premixed combustion and dpm. I am checking fluxes after the calculation. Mass flow balances out and shows the correct flows including the coal particles. however, when I check the heat transfer it shows less heat input from the dpm. Coal flow is 400,000 lb/h (mass flow is correct) and Coal HHV is 10,000 btu/lb (this value entered in coal calculator) so I should have 4,000mmbtu/hr heat input from dpm. Instead it shows me only 1,000mmbtu/hr from dpm.
FYI I am providing more than enough air to complete the combustion.
Any ideas?
Thank you in advance.
semo is offline   Reply With Quote
Coal combustion injection properties semo FLUENT 12 May 16, 2017 19:40
Problem on EDC model for coal combustion lei FLUENT 4 September 3, 2015 09:39
Coal combustion and ash reaction kinetics sega Fluent UDF and Scheme Programming 0 January 21, 2010 08:05
moisture in coal combustion Sheng FLUENT 3 June 15, 2003 19:43
Coal combustion with Fluent 4.5 or 5.0! Sriram Popuri Main CFD Forum 2 July 24, 1999 11:34
