-   -   problems running fluent through matlab (http://www.cfd-online.com/Forums/fluent/117950-problems-running-fluent-through-matlab.html)
galapago May 17, 2013 19:24
Hi everybody
I have some problems running fluent through matlab, in my laptop (serial processing) i used this instruction and i could run Fluent v14 without problems
!fluent 3ddp -g -i C:\Users\omar\Documents\MATLAB\alggambit\algorflue nt.jou
but now when i'm trying to do the same in a parallel process in the computer of a lab (with fluent 6.3.26, ansys 12.1, ansys 13 and ansys 14 installed)fluent open, but in 6.3.26 version. I deleted this version but still appearing(some weird).
in enviromental variables i put this path
C:\program files\ansys inc\v140\fluent\ntbin\win 64
like in my laptop, but in this computer i think that i need to change a parameter o maybe a path to mark that when I execute my matlab code i be abble to open fluent v14 , the problem is that i dont know where is this place or what i can do to solve it?
thanks a lot friends i hope you could help me
thanks in advance
Sorin October 10, 2013 09:20
Hi galapago,
It might be the PATH environment variable inside Matlab or at system level that it is set-up to the FLUENT 6.3.26.
Do you have the same problem when starting Fluent in the command line?
I would suggest launching Fluent in server mode instead of launching it from Matlab and then from Matla connect to Fluent and script Fluent from Matlab.
instead of executing from Matlab:
"fluent 3ddp -g -i C:/Users/omar/Documents/MATLAB/alggambit/algorfluent.jou"
do this:
1.execute Fluent from command line
fluent 3ddp -g -aas
2. Fluent will generate a file named aaS_FluentId.txt
3. start Matlab and connect to Fluent usinf Fluent generated file
fluent = actxserver(ANSYS.CoFluentUnit.1′);
fid=fopen(aaS_FluentId.txt,'r)
fluentkey=fscanf(fid,%s)
fclose(fid)
fluent.ConnectToServer (fluentkey)
tui=fluent.getSchemeControllerInstance();
4. execute your Matlab equivalent of algorfluent.jou from Matlab
To generate the Matlab equivalent of a line in algorfluent.jou use the following pattern:
if stringfluentCommand is the line in algorfluent.jou, the equivalent line in Matlab will be:
tui.DoMenuCommandToString(stringFluentCommand)
for example the following journal script in Fluent
rcd fluentcasedata
solve it 10
wcd fluentcasedata_saved
will have the following equivalent in Matlab:
tui.DoMenuCommandToString('rcd fluentcasedata')
rcd fluentcasedata('solve it 10')
tui.DoMenuCommandToString('wcd fluentcasedata_saved')
Thank you
Sorin
