Home > Forums > FLUENT
FLUENT Problem
Old   May 20, 2013, 23:42
Default FLUENT Problem
pyroknife is on a distinguished road
I did a mesh check in FLUENT and received the error "symmetry zone 54 has two adjacent cell zones." What does two adjacent cell zones mean? I tried searching for this error to no luck.
pyroknife is offline   Reply With Quote
Old   May 21, 2013, 05:35
OJ
oj.bulmer will become famous soon enough
I think you have fluid zone (or domains) at both the sides of symmetry, making symmetry as an internal face, or interface between two domains, which is not allowed. Try correcting your model by deleting the fluid zone at one side of symmetry or specify the symmetry such that it doesn't have any zone at the other side.
OJ
oj.bulmer is offline   Reply With Quote
Old   May 21, 2013, 15:34
OJ
Thanks for the reply. There is a fluid zone on both sides of the symmetry plane though. I have a complicated geometry that is essentially a pipe. I applied symmetry through the midplane of the pipe so there should be fluid on both sides of the symmetry, no?
Old   May 21, 2013, 15:40
OJ
Why do you need the fluid domain at both the sides of symmetry? symmetry is used so that you don't have to use a full geometry but only half one, because the flow structure in the other half is exactly mirror image of the one you are simulating! Remove the domain at one side of the symmetry, otherwise you won't be able to simulate.
OJ
Old   May 21, 2013, 15:46
OJ
I haven't had much experience with FLUENT/ANSYS. What do you mean by removing the domain at one side of the symmetry?
If we're thinking of the same thing, then I may have already removed it in design modeler with the symmetry feature. I attached an image of what I mean.
Red is my symmetry surface.
Not sure if this matters, but i tried simulating yesterday without solving that error and the solutions started diverging at about 30 iterations. Would this kind of error affect convergence?
Thanks!
Thread Tools
Trackbacks are On
fluent parallel problem in win7 x64 system dunga82 FLUENT 8 April 19, 2012 20:23
[ICEM] ICEM CFD boundary conditions conversion to Fluent problem kalyangoparaju ANSYS Meshing & Geometry 0 October 31, 2011 00:40
Problem in IMPORT of ICEM input file in FLUENT csvirume FLUENT 2 September 9, 2009 01:08
Fluent boundary conditions problem bobo FLUENT 2 July 3, 2009 06:28
Fluent parallel license problem brothershuai Main CFD Forum 0 July 1, 2009 15:41
