Fluent journal file
Old   August 7, 2023, 14:29
Default Fluent journal file
EmmaKate
emmakateh is on a distinguished road
I am trying to create a journal file in order to be able to set the memory usage of each solver processor used in fluent when I open fluent and the journal file from the command line:
fluent 3ddp -t2 -sl 1000 -i journal.jou
Only problem is that I can't figure out how to set up the environment tab from the journal... I need the environment tab set up in order to be able to compile UDfs properly.
/file/set-tui-version "20.1"
; Set up compilation environment for UDF
(cx-gui-do cx-set-udf-compile-env #t)
/file/read-case dp_3d_LH2_tank.cas.h5
(cx-gui-do cx-set-list-tree-s... this is what i had but it doesnt work, has anyone done this before?
emmakateh is offline   Reply With Quote
Old   August 7, 2023, 21:36
Alexander
AlexanderZ will become famous soon enoughAlexanderZ will become famous soon enough
any reason to compile inside journal?
compile udf separately before actual simulation
best regards
press LIKE if this message was helpful
AlexanderZ is offline   Reply With Quote
environment, fluent, journal
[openSmoke] LaminarSMOKE compilation error mdhfiz OpenFOAM Community Contributions 7 October 4, 2022 13:57
[foam-extend.org] Problems installing foam-extend-4.0 on openSUSE 42.2 and Ubuntu 16.04 ordinary OpenFOAM Installation 19 September 3, 2019 18:13
[foam-extend.org] problem when installing foam-extend-1.6 Thomas pan OpenFOAM Installation 7 September 9, 2015 21:53
SparceImage v1.7.x Issue on MAC OS X rcarmi OpenFOAM Installation 4 August 14, 2014 06:42
DecomposePar links against liblamso0 with OpenMPI jens_klostermann OpenFOAM Bugs 11 June 28, 2007 17:51
