Home > Forums > FLUENT
Reverse Flow and Convergence
Old   May 24, 2013, 14:11
Default Reverse Flow and Convergence
myty is on a distinguished road
Hi Everyone, when i am running natural converging heat transfer, residuals are converging smoothly but with a message that "reverse flow at in/out", is that a problem with solution or its not going to do anything with solution. Thanks
myty is offline   Reply With Quote
Old   May 27, 2013, 03:35
Muhammad Aqib Chishty
MAC88 is on a distinguished road
Send a message via Skype™ to MAC88
I think you have recheck your boundary conditions.
How far is your outlet? May be you have to increase that distance too!!!
Best of luck!!!
MAC88 is offline   Reply With Quote
Old   May 27, 2013, 12:57
Hey Aqib,
Thanks for your reply, i have a very simple setup of two parallel vertical plates (2D), I should make an imaginary outlet and a real one so that i could simulate my real dimensions and could avoid this message, is it what u r suggesting?
Old   May 27, 2013, 13:34
I don't know what you are trying to say about imaginary outlet!
What boundary conditions you are using?
How the flow physics of your case is behaving?
Regards:
Chishty
Old   May 27, 2013, 13:40
I have pressure inlet/outlet BC. my geometry is 12.5cm long straight channel. residuals are smoothly converging.
Old   May 28, 2013, 03:21
What about the flow pictures?
Anything reversal flow in the domain?
Thread Tools
Trackbacks are On
Convergence Centurion2011 FLUENT 29 August 27, 2016 03:19
momentum & x-vel convergence, and reverse flow problem cinwendy FLUENT 0 April 17, 2013 02:19
Convergence problem with target mass flow rate ADL FLUENT 2 May 29, 2012 21:11
3D Fluid Flow Convergence problem Emily FLUENT 2 March 21, 2007 23:18
Convergence for inviscid flow over sylinder Rjakk Main CFD Forum 2 March 21, 2007 11:53
