High CL lift coefficient in Stall Angle of attack airfoil |
April 26, 2016, 20:27 |
Anggie Restue Saputra
Rep Power: 10 |
I did a flow simulation over airfoil NACA 0015 using ansys fluent. Everything is ok in values of CL and CD for AoA 0 degree till 10 degree. But when i did simulation in AoA 15 degree values of CL is very high arround 1, it should be the value of CL in this AoA is low arround 0.4 cause 15 degree is near the stall angle (due to experiment result).
Whats wrong with my simulation? Thanks before |
Ffd_control_point_2d | feiyi | SU2 | 4 | September 30, 2019 12:42 |
Lift Coefficient vs Angle of Attach for Pitching Airfoil | fkanyako | FLUENT | 3 | July 16, 2014 07:35 |
Lift Coefficient vs Angle of Attach for Pitching Airfoil | fkanyako | Fluent UDF and Scheme Programming | 0 | January 29, 2014 03:17 |
Analysis of angle of attack vs lift generated | vikhattangady | FLUENT | 0 | October 31, 2013 04:42 |
Lift Coefficient Vs. Angle of Attack | cfd_pro | Main CFD Forum | 1 | August 23, 2002 17:21 |
