Home > Forums > FLUENT
Non-newtonian fluid flow
Old   May 27, 2013, 12:35
Default Non-newtonian fluid flow
C.C
CC
C.C is on a distinguished road
Hi all,
I'm simulating the turbulent flow of a non-Newtonian fluid in a pipe using Fluent.
I have some doubts related with the way as Fluent solve the complete set of equations:
1. As the dynamic viscosity is introduced as a function of shear rate/strain rate in an UDF, where can I find the way as Fluent solve the set of equations? Is the same way as for Newtonian fluids?
2. If the low-Re k-e turbulence model is enable: what happens when I enable the non-Newtonian modification for Lam-Bremhorst model? "/define models viscous turbulence-expert non-newtonian-mnodification?"
3. How can the low-Re k-e turbulence model implemented in Fluent be modified?
I hope someone can help me...
Regards
C.C is offline   Reply With Quote
Thread Tools
Trackbacks are On
Want Impeller Driven Fluid Flow: What Inlet and Outlet BC to use for Centrifugal Pump Zev Xavier FLUENT 3 May 9, 2016 06:42
How to calculate the fluid flow through a surface lynx OpenFOAM Paraview & paraFoam 4 January 20, 2016 12:58
Review: Reversed flow CRT FLUENT 0 July 20, 2012 13:03
mass flow in is not equal to mass flow out saii CFX 2 September 18, 2009 08:07
Inviscid Drag at subsonic, subcritical Mach # Axel Rohde Main CFD Forum 1 November 19, 2001 13:19
