Solver settings in fluent for solid fluid both in a geometry
Old   May 30, 2013, 01:58
Exclamation Solver settings in fluent for solid fluid both in a geometry
Parampreet Singh
Prince Jassal is on a distinguished road
HELLO EVERYONE,
I AM MODELING AXISYMMETRIC JET IMPINGEMENT WITH 9 JETS PLACED IN AN ARRAY AND ABOVE A HEATED PLATE WHICH RECEIVES HEAT FLUX FROM THE BOTTOM FACE AND THE UPPER FACE OF THE PLATE IS INTERACTING WITH FLUID FROM THE JETS AND AMBIENT. I DID MODELING IN GAMBIT 2.3.16 AND FLUENT VERSION IS 6.3.26,USING 3D MODEL AND INCOMPRESSIBLE PBNS EQUATIONS.
1) USED APPEND FILE TOOL TO SEPARATELY MODEL DOMAIN AND BASE PLATE FILES BOTH AT THE SAME TIME
2) THEN I USED THE BOUNDARY CONDITIONS. IN MY CASE THE HEAT FLUX AT THE BOTTOM FACE IS 8333 W/m2 with A TEMPERATURE OF 313 K AT START.
3) I USED INTERFACE BOUNDARY COND. FOR THE FLUID SOLID INTERFACE ( TOP FACE OF HEATED PLATE) AND ALSO INTERFACE BC WAS USED FOR THE SIDES OF THE PLATE AS WELL
4) PROBLEM PART IS :- HOW DO I INPUT THE BOUNDARY COND FOR THESE SIDES AND THE TOP WHEN THEY ARE INTERFACE AS IN MY PROBLEM THE SIDES ARE INSULATED AND THE TOP FACE IS RECEIVING HEAT FROM THE BOTTOM ONE.HOW TO INPUT BC's FOR THESE..AND ALSO HPW TO PLOT TEMPERATURE CONTOURS FOR THESE????
PLEASE HELP
Prince Jassal is offline   Reply With Quote
boundary conditions, interface, solid fluid both, temperature contours
Fluid Solid Interface in Fluent saisanthoshm88 FLUENT 2 July 17, 2012 05:31
Settings in Solver Control Roland R CFX 1 October 12, 2011 06:44
Problem Interface Solid Fluid with wall velocity Solver v12 hills1 CFX 2 October 12, 2009 05:36
interfacing a fluid solver with abaqus Tuhin Rakshit Main CFD Forum 0 June 16, 2005 10:03
Terrible Mistake In Fluid Dynamics History Abhi Main CFD Forum 12 July 8, 2002 09:11
