Tutorial of open channel
Old   November 8, 2012, 17:59
Default Tutorial of open channel
Rohit kumar Mittal
rkmittal1108@gmail.com is on a distinguished road
Guys,
please does anyone have a tutorial of designing an open channel and determination of its characteristics using fluent?
its an urgent
rkmittal1108@gmail.com is offline   Reply With Quote
Old   November 9, 2012, 00:09
Far
Sijal
Far has a spectacular aura aboutFar has a spectacular aura about
Send a message via Skype™ to Far
see this
http://hpce.iitm.ac.in/website/Manua...ug/node936.htm
http://www.cfd-online.com/Forums/flu...using-vof.html
http://web.unbc.ca/~yqwang/CFD-2008-Wang.pdf
Far is offline   Reply With Quote
Old   November 9, 2012, 04:00
Rohit kumar Mittal
thanks for the tutorial sir,
i hope this will be very helpful to me.
Again thank u sir
Old   November 14, 2012, 06:49
Rohit kumar Mittal
I have an open channel with some inclination i.e. negative slope.
I have done its modelling as well as meshing.
In fluent, i have done following operations-
(1) General- Pressure based solver and steady flow
Model- volume of fluid, checked open channel flow and body implicit force
(2) checked energy equation
(3) selected k-epsilon model
(4) Phases- primary phase- water
secondary phase- air
(5) Boundary conditions-
for velocity inlet: in momentum, for mixture, i have given zero gauge pressure and zero velocity. Also i have given hydraulic intensity 10% and hydraulic diameter A/P.
for pressure outlet: same as that for velocity inlet
Symmetry walls: default conditions
(6) Solution method- PISO
and all default conditions
Is there something else which i am missing because i am not getting the correct velocity profile although pressure profile which i am getting, is correct to be linear?
Please help me. Its an urgent.
Old   November 19, 2012, 04:38
Rohit kumar Mittal
anyone please reply............
I am confused
Old   November 23, 2012, 11:18
Rohit kumar Mittal
What ever is the volume fraction of water, i am getting the same velocity profile against depth, how this can be possible?
Old   September 1, 2013, 08:02
Andrey Yakovchuk
einandr is on a distinguished road
  • Only the heavier phase should be selected as the secondary phase.
Check the 26.3.2 page in user guide.
einandr is offline   Reply With Quote
Complex problem: Open Channel Flow lett FLUENT 18 November 10, 2018 19:30
[swak4Foam] groovyBC in openFOAM-2.0 for parabolic velocity bc ofslcm OpenFOAM Community Contributions 25 March 6, 2017 11:03
VOF modelling open channel river flow Matthew Roberts FLUENT 6 July 31, 2009 13:52
pressure outlet (open channel flow) Willem Brantegem Main CFD Forum 0 April 3, 2007 10:39
VOF scheme for open channel flow yan FLUENT 1 May 21, 2005 01:21
