Steady State Jet Impingement
Old   May 28, 2013, 04:33
Post Steady State Jet Impingement
Smaras
Smaras is on a distinguished road
I have problem in the start. I am doing this simulation of supersonic jet impingement of air (incompressible ideal) on a flat plate. My settings for simulation are as follows:
operating pressure: 101325 pas
Pressure based+ Steady
1. Model:
Energy+ Kw SST
2. Boundary Condition:
Inlet: velocity input (727.07 m/s)
Outlet: Pressure Outlet 0 gauge pressure
3. Solution Method:
Scheme: Simple
Pressure: Presto
URF: Pressure 0.3 Density/BF 0.5 Momentum 0.5 Tke/SDR 0.8 TV/Energy 1
Now i cannot go further then 20 iterations and its give an error of floating point error.
temperature limited to 1.000000e+00 in 492 cells on zone 12 in domain 1
temperature limited to 5.000000e+03 in 10643 cells on zone 12 in domain 1
turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 21 cells
13 6.8784e+03 9.8749e-01 6.2555e-01 3.9413e+07 1.8524e+01 4.4528e-02 3.2878e+06 5:49:40 99987
temperature limited to 1.000000e+00 in 2273 cells on zone 12 in domain 1
temperature limited to 5.000000e+03 in 16155 cells on zone 12 in domain 1
turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 342 cells
14 4.8991e+07 8.0444e-01 1.9110e-01 1.1793e+10 3.9392e+00 9.6625e-01 2.0071e+06 4:39:44 99986
Divergence detected in AMG solver: temperature
Divergence detected in AMG solver: temperature temperature limited to 1.000000e+00 in 6325 cells on zone 12 in domain 1
Primitive Error at Node 0: floating point exception
Primitive Error at Node 1: floating point exception
Primitive Error at Node 2: floating point exception
Primitive Error at Node 3: floating point exception
Primitive Error at Node 4: floating point exception
Please if anybody knows about this. Would be thankful for the help.
Smaras is offline   Reply With Quote
Old   May 29, 2013, 09:40
Jim Knopf
JimKnopf is on a distinguished road
try to deactivate the second order gradients for the temperature.
(rpsetvar 'temperature/secondary-gradient? #f)
(rpsetvar 'temperature/shell-secondary-gradient? #f)
Greetz
Jim
JimKnopf is offline   Reply With Quote
Old   May 30, 2013, 02:05
Default Error resolved
Parampreet Singh
Prince Jassal is on a distinguished road
All you need to do is to adjust the under relaxation factors for various field. Its in the solve menu...
Hope it helps
regards,
prince
Prince Jassal is offline   Reply With Quote
Old   May 31, 2013, 04:13
Smaras
Originally Posted by JimKnopf View Post
Greetz
Jim
Thanks Jim for replying but by that time i was away and yesterday was holiday in my country.
I have question regarding this isnt used for tetra mesh. Since I am using hexa meshing.
Regards,
Smaras
Old   May 31, 2013, 04:14
Smaras
Hope it helps
regards,
prince
Thanks Prince,
Did tried that and now comparing my results with compressible flow....with same configuration.
Regards,
Smaras
Old   June 1, 2013, 04:01
Jim Knopf
Hi Smaras,
am I right that you are trying to simulate a supersonic jet with incompressible air? I'm wondering if supersonic flows can be simulated that way, can they?
Did you try to run compressible simulations?
Anyhow impinging jets are a bit nasty. In my cases of subsonic flows we experienced that the RNG and the Realizable k-epsilon model gave a better stability. So you might try a different turbulence model.
Greetz
Jim
Old   June 4, 2013, 04:58
Smaras
Hi Smaras,
Greetz
Jim
Hello Jim,
yes you are right, i am working on simulating jet with in-compressible air. And till now i am getting good results. As i am counter checking with previous research of Annie Nordquist and Morshed Alam et all research papers for compressible flows.
And no for me KE or even realizable isn't working, and again my supervisors arentz fond of KE
Now want to find the BC for the same flow rate and pressure profile at the interface. I have some how get some of my result pretty close as my mistake was when i was doing in SST it automatically checked viscous heating which in my case wasn't applicable.
But still i am open for suggestions.
Best Regards
jet impingement, steady state, supersonic flow
mass flow in is not equal to mass flow out saii CFX 12 March 19, 2018 05:21
Solver for transonic flow? Martin Hegedus OpenFOAM Running, Solving & CFD 22 December 16, 2015 04:59
error message cuteapathy CFX 14 March 20, 2012 06:45
Constant velocity of the material Sas CFX 15 July 13, 2010 08:56
steady state, laminar vof_model Garima Chaudhary FLUENT 0 May 24, 2007 03:11
