June 4, 2013, 05:34 |
centrifugal compressor analysis
farzad
Rep Power: 12 |
Dear all
this is Farzad, and I want ti simulate a centrifugal compressor, but I have some problems. I use blade-generator and I exported it to design-modeler,I mesh it, now I face a problem in fluent(solver) sectio. 1- I use MRF , but I don't know the exact rotation direction, is it (Z) or (-Z)? 2- in tutorials they use oressur inlet and pressure outlet, why? do we must know these quantities? 3- after all when I run calculations, after few iterations I observe REVERSED FLOW. I appreciate your helps in advance. Farzad Last edited by farzadmech88; June 4, 2013 at 10:48. |
June 4, 2013, 05:39 |
farzad
Rep Power: 12 |
this is my mail problem:
""I am doing CFD analysis of compressor in FLUENT. but i am facing the problem of REVERSED FLOW at inlet as well as outlet with Pressure outlet condition. i am using density based solver.Is it appropriate?? If i am using IDEAL GAS as fluid then it shows very large values of ranges pressure, temperature and velocity."" |
centrifugal compressor |
Want Impeller Driven Fluid Flow: What Inlet and Outlet BC to use for Centrifugal Pump | Zev Xavier | FLUENT | 3 | May 9, 2016 06:42 |
Autoblade centrifugal pump template | mahdi balali | Fidelity CFD | 3 | February 18, 2014 08:56 |
Centrifugal Pump Cavitation problem or not. | ismael.s | CFX | 13 | February 27, 2012 08:00 |
How to model flow of centrifugal fan? | Peter | Main CFD Forum | 0 | April 2, 2008 06:07 |
centrifugal pump and centrifugal fan | Mangesh | Main CFD Forum | 3 | January 3, 2006 11:21 |
