-   -   How far to extend boundary (http://www.cfd-online.com/Forums/fluent/119022-how-far-extend-boundary.html)
MachZero June 8, 2013 09:11
Hello All,
I am simulating a centrifugal fan to try and predict a fan curve. An experiment was done, so I have built my geometry to try and match the experiment. At the exit of the fan, a 2" tube is connected as the exhaust. This tube exhausts into atmosphere. Since my flow is still incompressible, I ended the domain at the end of this tube and called it a pressure outlet at 0Pa.
One thing that I always struggle to figure out is, should I extend this outlet further? Should I model the room that it is in? If so, how far do I need to extend. If I extend the domain and call all the extended walls pressure outlets, then I get reversed flow continuously, which slows the simulation down tremendously. How are these types of things handled by the pros out there?
Any information or examples would be awesome.
sina.sh June 8, 2013 23:49
Dear MachZero
you should extend your region until the effects of up wind boundary condition on down wind BC be negligible. its Try and Error!
Regards
MachZero June 9, 2013 09:16
Thank you for your response. Do you have any recommendations on how to check for this? What kind of approach to take? For example, should I extend it until there is almost no pressure gradient at the exit? Should the extension be just an extended tube or should it be a large open section representing a room. I look forward to hearing your thoughts. Thanks!
sina.sh June 9, 2013 23:46
Yes. For best solution, it should be larger than tube for example: large box. plz plot a variable (for example Uvelocity) in your main domain and each time -when you change extended domain- check deviation of variable from last one. if no change had been seen so size of extended domain is ok.
