-   -   interface not working, bug in fluent? (http://www.cfd-online.com/Forums/fluent/119043-interface-not-working-bug-fluent.html)
MachZero June 8, 2013 16:51
I am working with a sliding mesh to simulate a fan. I am using a mesh interface between the moving zone and the non-moving zone. However, fluid does not appear to be passing through the zone, and the simulation diverges after about 20 iterations. Has anyone seen this before?
I have gotten this to work recently, then I changed the geometry, remeshed, and used the same settings. This time however, no luck. I think this is a bug, but possible I am making a simple mistake. Has anyone seen this before?
sina.sh June 8, 2013 23:38
Dear Mach zero
what is your boundary condition in inlet and outlet? is divergence on mass balance?
Regards
Sam Engineer June 9, 2013 07:22
Hi MachZero
you should check interface bc in your mesh generation software.
first plz check element size of mesh in two sides of interface.
