Home > Forums > FLUENT
Converge
Old   June 9, 2013, 23:25
Default Converge
tang
tangfl is on a distinguished road
hi,
I'm study on external flow in sand domain, does i always need to wait the solution until converge. As it take longer time to converge for external flow and in transient state..
tangfl is offline   Reply With Quote
Old   June 10, 2013, 00:33
sina
sina.sh is on a distinguished road
Originally Posted by tangfl View Post
hi,
Dear tang
if you want final solution, you must use steady-state solver not transient.
Regards
sina.sh is offline   Reply With Quote
Old   June 10, 2013, 00:40
tang
when i use steady state, error will be detected:
divergence detected in AMG solver: k increasing relation sweep
Why this error will appear??
Old   June 10, 2013, 00:54
sina
If all settings are ok, usually this error appears when initial conditions for k and epsilon are incorrect. Plz change initial conditions for k & epsilon.
Old   June 10, 2013, 02:11
tang
i'm setting :
Inlet. Turbulent intensity = 5%. Turbulent viscosity ratio= 10
Outlet turbulent intensity=1% turbulent viscosity ratio= 10
Any problem in my setting ?
Old   June 10, 2013, 02:21
sina
i'm setting :
its your boundary condition and seems ok! you should change INITIAL CONDITION. By default initial condition for k and epsilon is 1 in fluent. Plz see
Help with k epsilon values of turbulence
Regards
Old   June 10, 2013, 06:47
tang
So, I should lower my k and epsilon value. Does I need to change relaxation values?
Why should I change my k and epsilon value? Actually what value is the most possible for k and epsilon
Old   June 10, 2013, 07:27
sina
Yes. you should select lower value for k and epsilon. initial value of k and epsilon are depended to your problem. but initial values havent any effect on final solution. so change value of k and epsilon to 0.001 and 0.0001 respectly.
Regards
Old   June 10, 2013, 23:00
tang
I'm trying to lower my k and epsilon in my solution control, however the error (divergent detected) become more faster (in lesser iteration calculation).
Old   June 10, 2013, 23:29
sina
Is your mesh dimension correct?
Old   June 11, 2013, 02:06
tang
how to check whether why mesh is correct?? There is no warning on my mesh,,, Do u mind send me your email...i will send my case data for u, to better understanding on my fluent setting.
Old   June 11, 2013, 02:27
sina
I send my mail for you (private message). please send your geometry dimension too.
tnx
Old   June 26, 2013, 03:22
tang
i already send to u past two week..
Old   September 21, 2013, 21:53
Default help
  #14
guilin han
shmilyhan is on a distinguished road
hi,
do you have converge sofeware ?Can you give me a Decoding software?
shmilyhan is offline   Reply With Quote
Thread Tools
Trackbacks are On
can't converge in FLUENT ok___ko FLUENT 1 April 30, 2013 02:47
Gmres fails to converge, but LU is fine sbabbi Main CFD Forum 1 April 11, 2013 08:54
k and epsilon were hard to converge in multiphase model of Fluent Yanlong Li ANSYS 0 January 2, 2013 06:25
HELP !In relaxtion factor converge is taken or not MANOJ KUMAR FLUENT 5 September 22, 2005 04:16
Converge problem for multiphase flow Jen FLUENT 4 July 20, 2005 16:52
